ipv6,ipv4 mixed enviroment-scenario
Answered Question
Sep 5th, 2010
  • Bronze, 100 points or more
Hi  every body
I have few questions
Scenario # 1
     h1(ipv6/ipv4), h2(ipv4), h3(ipv6)  , all are connected to hub.
Is it possible for h1 to have  ipv4 and ipv6 addresses associated with the same NIC connected to  hub?
will h1 use  ipv4 address when it wants to talk to h2(ipv4)  and use ipv6 address when it wants to talk to ipv6 host3?
Can we say h1 is dual stack host because it has both ipv4 and ipv6  configured on its port?
Scenario #2
h1( ipv4)  and h2(ipv6)  and  router are connected to hub. Router is acting as a gateway.  can router  forward   the ipv6 packets received from h2(ipv6) and ipv4 packets from  h1(ipv4)  on its port connected to hub?
  Scenario #3
is it correct   that we need dual stack some where to implement  tunneling ?
For example:
H(ipv6)-------R--ipv4 network-----R-----H2(ipv6)
R stands for router.   Here  router will  perform   ipv6 to ipv4 tunneling so it  should be   dual stack   correct?
H(ipv6/ipv4)---------( ipv4  network)------H(ipv6/ipv4)
Dual stack has to be implemented on Hosts  to implement tunneling   correct?
thanks and have a great  weekend.
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Sarah,
scenario1:
your understanding is correct and h1 is a dual stack host.
yes, the hub or L2 switch is agnostic of upper layers
yes
scenario2:
yes, there is no difference for hub L2 switch between an host NIC and a router NIC
notice that IPv6 has a different ethertype (0x86DD) then IPv4 (0x0800) so there is no risk of confusion for hosts.
scenario3:
yes your understanding is correct in first case R1 and R2 have to be dual stack, in second case are the hosts to be dual stack to send IPv6 packets into IPv4 packets over an IPv4 cloud.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Sun, 09/05/2010 - 08:53
  • Hall of Fame,
    Founding Member
Hello Sarah,
scenario1:
yes
scenario2:
scenario3:
Hope to help
Giuseppe
