Change SSH Port on 3750G?
Sep 5th, 2010
Hello, we have a Cisco WS-C3750G-24T running IOS 12.2(25)SEE (image C3750-IPSERVICESK9-M). Historically, I have changed the port using "ip ssh port" however this device doesn't seem to support this:
(config)#ip ssh port ?
% Unrecognized command
Any ideas on how to change the SSH port?
-Chris
Leo Laohoo Sun, 09/05/2010 - 15:12
To enable SSH, try this:
line vty 0 15
transport input ssh telnet
Peter Paluch Sun, 09/05/2010 - 15:15
Leo,
Activating the SSH is fine but I believe that the OP wanted to move the SSH from the default TCP port 22 to a different port. The command ip ssh port is indeed unsupported on 3750 so I personally do not see any other way to make the SSH on a 3750 to listen on a different TCP port. Any idea?
Best regards,
Peter
Leo Laohoo Sun, 09/05/2010 - 15:26
Yup.  Definitely mis-understood everything.  He he he ...
Nope.  Don't have any idea how to move the standard SSH port to some other one ...
Related Content
