ACS 5.1 Anyconnect Atributes
Sep 5th, 2010
Can some one explain me the steps to configure AnyConnect tunneling protocol of svc and so forth in the ACS 5.1 please.
Also I will be highly appreciated if there's a reference document available.
Thanks in advance.
Nathaniel Austin Tue, 09/07/2010 - 16:01
Hi pemasirid,
The following are all the attributes that the ASA accepts for VPN connections, including AnyConnect:
In terms of where to configure them in ACS, you would add them into the appropriate Authorization Profile that you are returning to your VPN clients. Go to Policy Elements > Authorization and Permissions > Network Access > Authorization Profiles, and create one (or edit one you already have). Go to the tab called Radius Attributes and pick the dictionary type "Radius-Cisco VPN 3000/ASA/PIX 7.x", and those attributes from the link above should be there to choose and you can enter your values.
Then assign that Authorization Profile to your Access Policy rule that is being matched for your connections.
