Cisco 2821 crashes couple of times a day
Answered Question
Sep 5th, 2010
couple of days ago my Cisco 2821 router started crashing every 4-5 hours with the same error. As I remember, no configuration changes were made almost for 2 weeks.
There is the context:
TESTRR01#sh context
System was restarted by bus error at PC 0x4177FC80, address 0x813B at 18:51:09 BKD Sun Sep 5 2010
2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Compiled Fri 10-Oct-08 00:05 by prod_rel_team
Image text-base: 0x4007D740, data-base: 0x42A66200
Stack trace from system failure:
FP: 0x45C3F3F8, RA: 0x4177FC80
FP: 0x45C3F450, RA: 0x4177B03C
FP: 0x45C3F488, RA: 0x41598DD0
FP: 0x45C3F4E8, RA: 0x4159B81C
FP: 0x45C3F568, RA: 0x4159C168
Fault History Buffer:
Technical Support:
Signal = 10, Code = 0x44AC0000, Uptime 07:58:48
$0 : 00000000, AT : 000000F4, v0 : 00000007, v1 : 00000008
a0 : FFFFFFFF, a1 : 45CDC1C4, a2 : 00000000, a3 : 00000000
t0 : 00000008, t1 : FFFFFFFF, t2 : 00000001, t3 : 00000815
t4 : 00000814, t5 : 00010000, t6 : FFFFFFFF, t7 : 00000002
s0 : 0000FFFF, s1 : 45CDC1C4, s2 : 00000000, s3 : 00000814
s4 : 00000000, s5 : 00000006, s6 : 00000000, s7 : 44CA72C4
t8 : 00000008, t9 : 00000000, k0 : 3040A801, k1 : A000F000
gp : 44783B80, sp : 45C3F3F8, s8 : 00000000, ra : 4177B03C
EPC : 4177FC80, SREG : 3400FF03, Cause : 00000010
Error EPC : BFC0900C, BadVaddr : 0000813B
CacheErr : C0800D7B, DErrAddr0 : 04CB92F8,
                            DErrAddr1 : 05CDFFD8
DATA_START : 0x42A66200
TESTRR01#
Any help is appreciated.
Thank you very much.
Correct Answer by vragotha about 6 years 6 months ago
The router is crashing due to CSCsv13099. You need a valid CCO id to view the details. Upgrade IOS to 12.4(24)T1 or higher
Correct Answer by Leo Laohoo about 6 years 6 months ago
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
It's a bug.
Load the next level of IOS into the CF.  If it crashes once more, the new IOS will load.
Overall Rating: 5 (2 ratings)
Leo Laohoo Sun, 09/05/2010 - 21:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Do you have the crashinfo file?
Why don't you try to upgrade the IOS?
Safar Safarov Sun, 09/05/2010 - 21:23
Here is it.
I have one more 2800 series router and it works OK with the same IOS.
Correct Answer
Leo Laohoo Sun, 09/05/2010 - 21:29
  • Hall of Fame,
    2017 LAN, Wireless
It's a bug.
Leo Laohoo Sun, 09/05/2010 - 22:42
  • Hall of Fame,
    2017 LAN, Wireless
I've used that and I don't see any issue.  I'm currently using 15.1(2)T1.
vragotha Mon, 09/06/2010 - 01:30
  • Silver, 250 points or more
safar.safarov wrote:
Is c2800nm-adventerprisek9-mz.151-1.T.bin OK?
As long as you have enough DRAM and Flash to run it. Check the recommended values on CCO
Safar Safarov Mon, 09/06/2010 - 02:22
Have 1024 mb RAM on it and unfortunately 64 mb CF, but I have one 128 mb from SanDisk vendor, hope it won't be a issue.
Minimum values are 512 mb RAM / 128 mb CF.
Leo Laohoo Wed, 09/08/2010 - 15:26
  • Hall of Fame,
    2017 LAN, Wireless
ISR G1 (except the 870) can support up to 2Gb CF.
Leo Laohoo Wed, 09/08/2010 - 15:27
  • Hall of Fame,
    2017 LAN, Wireless
Safar Safarov Tue, 09/14/2010 - 05:11
Thank you for the info. It works great now, but I'm planning to try with c2800nm-advsecurityk9-mz.151-1.T.bin as I don't need all those features included into Advanced Enterprise Services.
Correct Answer
vragotha Sun, 09/05/2010 - 22:06
Related Content
