help. ezvpn issues.
Sep 5th, 2010
ok. we have a UC500 at work on a dynamic ip that never changes. i am attempting to setup an ezvpn connection with an ASA, mainly for use with VOIP. the asa will connect, grab a vpn IP, and seem like it's connected. however, i cannot access resources on the remote network. when i connect with the vpn client on my system, i get full access.
here's my 'show run' because i know you'll want it.
Result of the command: "show run"
: Saved
ASA Version 7.2(4)
hostname asa
enable password [removed] encrypted
passwd [removed] encrypted
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group Verizon
ip address pppoe setroute
interface Vlan3
nameif dmz
security-level 50
ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
monitor-interface inside
monitor-interface outside
monitor-interface dmz
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group Verizon request dialout pppoe
vpdn group Verizon localname mlwartman
vpdn group Verizon ppp authentication pap
vpdn username mlwartman password ********* store-local
dhcpd auto_config outside
dhcpd option 3 ip
dhcpd address inside
dhcpd enable inside
vpnclient server  [removed]
vpnclient mode client-mode
vpnclient vpngroup EZVPN_GROUP_1 password ********
vpnclient username mlwartman password ********
vpnclient management tunnel
vpnclient enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum: [removed]
: end
i have been banging my head against this for too long, being stuck at this very place. i have been told before that the ezvpn wizard should provide all the connectivity i need to establish a VOIP connection with the UC to support our IP phones, but i can't even get it to provide connectivity to desktops, much less connect the phones to the call manager. please help...
