How to setup Port forwarding with two gateways
Sep 6th, 2010
Hey Guys
I have a pretty simple network and have some questions in regards to port forwarding with two gateways. Please see the attached file for reference.
Basically what i would like to achieve is enable port 80 port forwards from two gateways on the same subnet to my webserver. The issue we face is the port forwarding works fine for the default router as it is the default gateway of the network. How do i allow the webserver to respond to requests from the secondary router. Is there a route command i need to add on the primary router so it is aware of the second router, or is the only option to have the second router on a seperate network and install two nic's in the web server
Nagaraja Thanthry Mon, 09/06/2010 - 01:03
On the second router, please try the following:
interface FastEthernet0/0
description Internet_Conn
ip address
no ip nat outside
ip nat enable
duplex auto
speed auto
interface FastEthernet0/1
description LAN
ip address
no ip nat inside
ip nat enable
duplex auto
speed auto
ip nat source static "webserver_Priv_ip" "webserver_pub_ip" extendable
access-list 101 permit ip any host webserver_pub_ip
route-map WebServer
match ip address 101
ip nat pool IntHosts "Free LAN address" "Free LAN address" netmask
ip nat source route-map WebServer pool IntHosts
This will NAT all the internet addresses to "Free LAN address" when the
request comes from the second internet connection. This way, the server will
respond back to the second router and router will be able to translate the
address back to its original internet address.
Hope this helps.
