Cisco SLM 2008, automatically change port setting (enable/disable)
Sep 6th, 2010
Is there a way to automatically change the port state (SLM 2008 switch) from enabled/100MB/1000MB  to the disabled state?
The setting change must occur on certain times of the day.
Or, if possible, based on port statistics (number of Mbytes sent/received).
For example by running a script on the switch itself,  or on a device connected to the switch (PC)?
Joachim Kern Mon, 09/06/2010 - 08:17
on a PC
you might want to look into an SNMP management system which can be scripted
or use Radius authentication to de-authorize the port at specific times
Joachim Kern Tue, 09/07/2010 - 07:09
sorry, no SNMP
my fault
you need to invest into a fully managed switch, seems the SLM series is too leightweight for that
Related Content
