Surendra BG Mon, 09/06/2010 - 05:12
  • Cisco Employee,
Send the error msg in text pad or something which will help me to see..
Surendra
Surendra BG Mon, 09/06/2010 - 05:13
  • Cisco Employee,
in the mean time.. did we try upgrading the software??
Surendra
Surendra BG Mon, 09/06/2010 - 22:40
  • Cisco Employee,
are we able t oaccess the AP using console access?? if yes, try assigning the ip address to the BVI interface..
conf t
int bvi 1
ip address
no shut
try accessing the AP using browser and see if we could access the GUI..
If the radio interfaces doesnt come up then.. we are hitting the below bug..
the AP is hitting the software bug.. to resolve the issue we need to..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsc79121
1-       to upgrade to version 12.3(8)JEA
2-       or to downgrade to version 12.3(7)JA2
Upgrade process
>> Get the console access to the AP and then connect the ethernet cable between the AP and the laptop.
>> Both the AP and the laptop should be in the same subnet..
>> Donwload the latest image from cisco.com and point the image in the TFTPd32 server
>> in the console access, issue the command.
archive download-sw /force-reload /overwrite tftp:///
Example..
AP# archive download-sw /overwrite /force-reload tftp://10.X.X.X/c1200-k9w7-tar.123-7.JA1.tar
if the above is not clear.. then i request you to open up a TAC case..
Surendra
Markprotk4 Mon, 09/06/2010 - 22:59
i can access console port but when AP 1200 run and stop at there. AP cant run ,i do not doing, I  cant config it. I dont know how to upgrade ?? plz help me !
Surendra BG Mon, 09/06/2010 - 23:35
  • Cisco Employee,
open up the hypertreminal and connect to it using restore defaults settings and then try..
Markprotk4 Tue, 09/07/2010 - 00:15
I' ve tried and i' ve used both MODE to reset AP original default but still nothing changes. HyperTerminal is to stop it (as a text file in my attach) and i do not what to do next. Plz help me fix it
Markprotk4 Tue, 09/07/2010 - 00:19
And i use the laptop to search the channel of the AP1200 but did not search any channel of distribution the AP1200
Markprotk4 Tue, 09/07/2010 - 00:41
Connect the ethernet port of the AP 1200 with my latop then open up the browser and https:// 192.168.0.26 ?
