Tracking Client usage stats
Sep 6th, 2010
Hi There,
I'm still finding my way around Cisco firewalls at the moment, and could use a little help regarding tracking clients usage.
What I'm after is a list of internal IP addresses, and the total download / upload stats from them.
I had a look at the monitoring graphs but to no avail...
I'm sure there must be something built into the ASDM v6.3(1) to do this, but for the life of me I can't find it.
Any help would be greatly appreciated.
Chris.
abinjola Mon, 09/06/2010 - 04:41
On ASDM------go to-------> firewall Dashboard----------------->.Home----------------->Top Usage Status---------->Top10sources/destination------------>choose (based on bytes)
The above will show you usage of top 10 sources/destination having maximum data-xfer thus consuming maximum bandwitdh
Hope this helps !
leedschamber202 Mon, 09/06/2010 - 06:05
Thanks for the quick response matey, unfortunately this doesn't help..
I've enabled the source / destination graph, and it's not showing any internal address only external.
What I'm looking for is something along the lines of:
192.168.0.1 - 200MB(D/S) - 100MB(U/S)
192.168.0.2 - .....
All I'm seeing at the moment is external address on that graph, even set my laptop downloading an 800MB file, and it's IP still isn't showing up on the list yet..
I guess what I'm after is a real-time graph showing which clients are downloading stuff all day long
Cheers
Chris.
abinjola Mon, 09/06/2010 - 06:58
I am afraid at this point what you are seeking is not there on ASDM
