Wireless network out of range - Win XP
Sep 6th, 2010
Hi all
I have some laptops at work with some wireless issues, I have some 1242AG access points with 2 ssid's broadcast, The issue is that some laptops can see both SSID's, but one of the SSID's is showing as out of range, but then I have another laptop which can see them both fine. Are we looking at a driver issue maybe on the laptop?
cheers
Carl
Elliott Shawd Mon, 09/06/2010 - 21:38
I wouldn't trust the number of bars.. Did you try to connect on either of the laptops?
SOcchiogrosso Tue, 09/07/2010 - 08:27
  • Bronze, 100 points or more
I would also see this as a driver problem.
I have AP 1252's and in a few offices, I have a Wi-Fi desktop that has an ideal signal with a laptop (roams around) that has a flaky connection and drops out. (Dell Latitude D620) after a driver update signal quality has improved.
