CSS without SSL Module needing sticky sessions
Sep 6th, 2010
Hello All,
If anyone can help with this sticky situation I'd appreciate it.
I have a customer with a CSS11501. He does not have an SSL module installed.
He has 2 blade servers, when he adds a web site, which is accessible over SSL, the CSS load balances client requests causing lost sessions, mostly lost pop-ups, it does not want stick to the same server.
I've configured the following:-
service web1
protocol tcp
port 443
keepalive type tcp
ip address 192.168.200.50
string web1
active
service web2
rotocol tcp
port 443
eepalive type tcp
ip address 192.168.200.51
string web2
active
content SSL_Web
add service web1
add service web2
rotocol tcp
port 443
vip address 1.2.3.4
application ssl
advanced-balance sticky-srcip-dstport
active
group web_Farm
  add service web1
  add service web2
  vip address 1.2.3.4
  active
I was attempting to get the client to stick to the server but unfortunately, this didn't work, the CSS seems to continue to send requests to both servers and they are getting scripting errors.
Once the customer turns off the second blade, all is ok.
I did try adding the string value to the service and configuring 'advanced-balance arrowpoint-cookie' in the content but the clients were unable to reach any web sites.
Best Regards Tony
litrenta Mon, 09/06/2010 - 07:40
  • Cisco Employee,
You should remove application ssl from the content rule. You should only use this if you are trying to do sticky based on ssl id with advanced-balance ssl. IF you are doing sticky via srcip do not use this.
tholmes@cistek-... Mon, 09/06/2010 - 08:58
Hi Litrenta,
Many thanks for the reply, do you think the config might be ok otherwise?
At the moment I can't test it as its live right now.
Regards Tony
jsirstin Wed, 09/08/2010 - 07:24
  • Cisco Employee,
Tony,
The config looks fine other than the "application SSL" under the content rule, and right now you are probing the servers with a tcp probe on port 80. If you want the probe to be on port 443 you should add the command "keepalive port 443" to both of the services. The CSS will default to port 80 for a tcp probe.
Jim
