paolo bevilacqua Mon, 09/06/2010 - 05:31
  • Hall of Fame,
    Founding Member
Very old switch, very old software, it does not make a difference if you update or not.
sudhir.rai Mon, 09/06/2010 - 05:42
Thanks for your reply ,
But do you mean cisco 2950C 24 port switch is not supported by cisco .
Also do you think  software should not  be upgraded .
Please share the reason as i have to give the strong reason to client to not to upgrade the software
Nagaraja Thanthry Mon, 09/06/2010 - 05:58
  • Cisco Employee,
12.1(22) EA13 is the latest software for that platform. You can certainly
ask your client to upgrade the software if there is a need to upgrade the
software. The device is still supported by Cisco. The last date of support
is October 20, 2013.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps628/prod_en...
-life_notice0900aecd806ea1da.html
NT
