Migration MGX ATM switch VISM T1 to C7600 T1.
Sep 6th, 2010
Hi Sir,
My customer used many T1-MUX to connect MGX-VISM T1. There are FXO, FXS, E&M, & Low Speed Data from 2.4K,9.6K to 64K, sync or async.
The MGX-VISM used AAL2 trunk,and codec G.729ab to handle Voice. MGX-VISM can connect FXO, FXS, & E&M to PBX.
The Low Speed Data, MGX-VISM used AAL2 trunk, and G.711 or Clear Channel to handle data. Also, MGX-VISM can connect Low Speed Data to other T1-Mux.
In the ATM netowk, I can use DS0-base to create virtual circuits to other site.
Now, I try to migrate these T1-MUX to C7600, from ATM network to IP/MPLS network.
Migration T1 of T1-MUX from MGX-VISM to C7600.
Can C7600 support DS0 cross-connection Pseudowire?
Do you have any suggestion about migration T1-MUX from ATM to IP/MPLS?
