reactive debugging in UCCX 7.0.1
Answered Question
Sep 6th, 2010
Hi All,
Last couple days I've had this weird issue happening with IPCC.
I've tried to debug couple of scripts, but they never get triggered, it's like application does not get triggered at all.
Although I call the trigger and it plays menu and actually works.
The script is fine, I know I'm putting correct script name when I debug, I've done it before, the same script, with no problem. It just stopped working last friday.
More info: It's HA solution, both servers are "IN SERVICE", it's a production network 24/7 CC, so I can't just restart the servers without a good reason.
Anything I should be looking into? any ideas???
Many thanks,
Correct Answer by Phuong Hoai Huynh about 6 years 10 months ago
Hard to say what is going on unless you look at the medt log
Try testing from the script editor on the uccx box and see what happens, this will let us know where the issue lies
We are trying to isolate if this is an issue due to the network or your UCCX has a problem with running the debug
If you do look at the MEDT you will see that the Script Editor fires of a request to the UCCX that it will be performing a debug on script XXXX
The UCCX will response to this and the Script Editor will then poll the UCCX till a call has hit the system.
Determine where the break down in the process lies, also try disabling any anti virus/firewall you have on the client pc should the test on the UCCX box works.
Overall Rating: 5 (2 ratings)
Jonathan Schulenberg Tue, 09/07/2010 - 05:28
  • Cisco Designated VIP,
    2017 IP Telephony
Are you sure you connected to the node currently processing calls? You may want to try logging into the other node with the Editor in case a failover occurred.
sufle Tue, 09/07/2010 - 07:52
Unfortunately that does not help, I did not mention in my first post, but I did try both servers just in case if that was the case.
Although normally I log on to the one that is Master on UCCX Engine service.
Still same issue.
sufle Tue, 09/07/2010 - 07:57
by the way, it shows this in status window...:
Error Debugging
Correct Answer
Phuong Hoai Huynh Wed, 09/08/2010 - 08:45
  • Bronze, 100 points or more
sufle Thu, 09/09/2010 - 03:17
Thanks a lot for your suggestions, I tried it on the server itself and it worked fine.
I'll see if I have something wrong on the PC.
Cheers,
Aaron Harrison Tue, 09/21/2010 - 02:59
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi All
Just to throw another suggestion into this - the most common reason for a debug not launching is a script error that means the script can't load into the engine in the first place. If you dial the app and get the 'system problems' prompt, then it's possible that the script isn't actually runnable. Take a look at the MIVR logs when the call is attempted to see what exceptions are logged or post up the log here.
If the script does execute but doesn't debug then obviously ignore this comment...
Aaron
instbt Tue, 09/21/2010 - 05:25
I never fixed the issue, although for me it works if I run debugging on the server itself. So it must be a client computer.
Although I have all ports open, and as I said it used to work before.
If you find the problem, let me know too... It's annoying having to troubleshoot the problem on the server.
Pablo Leiva Tue, 09/21/2010 - 05:59
  • Silver, 250 points or more
As a quick test, please try closing up the editor on the client PC. Right click on the Editor icon on the Desktop and select Properties> Compatibility tab. Check the box for 'Run this program in compatibility mode' and choose 'Windows 2000' from the drop down. Check if that makes any difference.
Hope that helps!
Pablo
