2921 Problem with VDPN and PPPoE
Sep 6th, 2010
Hello Folks,
Customer's got a problem.
He can't configure "protocol pppoe" on his 2921 in a VDPN group.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
vpdn-group test
protocol x <---- only l2tp or pptp are available, but no pppoe
I've searched the whole internet for a reason/solution but couldn't find anything...
My guess would be that he needs another IOS w/ another feature-set.
Can somebody enlighten me?
Kind Regards,
Peter Paluch Mon, 09/06/2010 - 08:08
Hello Tim,
In recent IOSes, the PPPoE access is configured under bba-group and not under a vpdn-group anymore.
This can be an example:
vpdn enable
bba-group pppoe global
virtual-template 1
If the PPPoE session has to be further forwarded via L2TP, an additional vpdn-group must be configured for this but to create a simple PPPoE concentrator, this configuration should work (note you still have to create the virtual-template interface referred to in the bba-group config).
Best regards,
