ASA 5510 ACL Question - Easy one I know..
Nagaraja Thanthry Mon, 09/06/2010 - 09:21
  • Cisco Employee,
It is a two step process.
Step 1: Create static NAT
static (inside,outside) tcp interface 636 "inside server IP" 636 netmask
255.255.255.255
Step 2: Create access-list
access-list outside_access_in permit tcp host "outside host1 IP" interface
outside eq 636
access-list outside_access_in permit tcp host "outside host2 IP" interface
outside eq 636
Step 3: Apply the access list (if you have not done so already)
access-group outside_access_in in interface outside
This configuration is applicable for ASA with OS version 8.2 and prior. If
you are running 8.3, then
object network Server
host "inside server ip"
nat (inside,outside) static interface service tcp 636 636
access-list outside_access_in permit tcp host "outside host1 IP" "inside
server ip" eq 636
access-list outside_access_in permit tcp host "outside host2 IP" "inside
server ip" eq 636
Hope this helps.
NT
Nagaraja Thanthry Wed, 09/08/2010 - 19:30
  • Cisco Employee,
Make sure that you are using the same name for the access-list as your
existing access-list on that interface (seems like it could be acl_out).
So, if that is the access-list is already applied to outside interface, then
modify the access-list as:
access-list acl_out permit tcp host "outside host1 IP" interface
outside eq 636
access-list acl_out permit tcp host "outside host2 IP" interface
outside eq 636
NT
Federico Coto F... Mon, 09/06/2010 - 09:21
  • Green, 3000 points or more
access-list outside permit tcp host x.x.x.x host internal_host eq 636
access-list outside permit tcp host y.y.y.y host internal_host eq 636
access-group outside in interface outside
i.e.
The above creates an ACL that permits TCP port 636 to host internal_host from hosts x.x.x.x and y.y.y.y
Note that internal_host should be the public IP of your internal host.
Also change TCP for UDP if needed.
I'm assuming there's no ACL applied in the outside interface already, if it is you should use that ACL.
Federico.
Federico Coto F... Mon, 09/06/2010 - 12:45
Please explain what your problem is?
No outbound traffic?
No inbound traffic?
What?
Federico.
Federico Coto F... Mon, 09/06/2010 - 12:51
I believe you're missing this line:
access-list acl_out in interface outside
Federico.
Federico Coto F... Mon, 09/06/2010 - 12:58
Sorry,
The command is like this:
access-group acl_out in interface outside
Federico.
Federico Coto F... Mon, 09/06/2010 - 13:25
Assuming you receive e-mail on port 25, check you have the following:
access-list acl_out permit tcp any host x.x.x.x eq 25
static (inside,outside) x.x.x.x REAL_IP
With the commands above you're allowing inbound SMTP traffic to x.x.x.x
Federico.
