Posible IKE starvation attack
Sep 6th, 2010
Dear Friends,
Possibly, i am facing a IKE starvation attack on my ASA 5550, which has 3000 tunnels and when the issue occurs it touches 5k+ due to duplicate SA resulting in high cpu. Pl help analyse.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
WI-GSMC-FORD-FW001# show processes
P
C         S
P         S
TATE
Runtime
SBASE
Stack   Process
Mrd
08064cc5
23e11a1c
09f6cfb4
121141078
23e0deb8
7368/16384   IKE Daemon
WI-GSMC-FORD-FW001# show proc cpu-usage non-zero
PC         Thread       5Sec     1Min     5Min   Process
08064cc5   1c5a42f0    56.5%    49.5%    25.4%   IKE Daemon
WI-GSMC-FORD-FW001# show processes cpu-usage sorted
WI-GSMC-FORD-FW001# show processes memory
Allocs
Allocated
Frees
Freed
Process
133488289
41475063393467
657482165
1458804983288
IKE   Daemon
217803927
569601130748
2178023909
69598573064
vpnfol_thread_timer
WI-GSMC-FORD-FW001# show processes internals
Invoked
Giveups    Ma
x_Runtime    Pr
ocess
2792259432
2783311168
8560.011
ssm4ge_cfg_poll_thread
1722975056
10473577
301.055
IKE   Daemon
WI-GSMC-FORD-FW001# show conn count
6713 in use, 38327 most usedb
WI-GSMC-FORD-FW001# show crypto isakmp sa
Active SA: 5763
Rekey SA: 7 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 5770
Show traffic
Maxi is on Outside interface input traffic = 40 Kbytes
WI-GSMC-FORD-FW001# show xlate count
54 in use, 55 most used
WI-GSMC-FORD-FW001# sho asp drop
Frame drop:
  Unsupported IP version (unsupported-ip-version)                              4
  No valid adjacency (no-adjacency)                                           41
  Reverse-path verify failed (rpf-violated)                              7395306
  Flow is denied by configured rule (acl-drop)                           1833326
  Invalid SPI (np-sp-invalid-spi)                                         136322
  First TCP packet not SYN (tcp-not-syn)                                    5735
  Bad TCP flags (bad-tcp-flags)
  TCP data send after FIN (tcp-data-past-fin)                                  1
  TCP failed 3 way handshake (tcp-3whs-failed)                              7605
  TCP RST/FIN out of order (tcp-rstfin-ooo)                                 4756
  TCP invalid ACK (tcp-invalid-ack)                                           14
  TCP replicated flow pak drop (tcp-fo-drop)                                 121
  TCP RST/SYN in window (tcp-rst-syn-in-win)                                  29
  IPSEC tunnel is down (ipsec-tun-down)                                     2054
  ICMP Error Inspect no existing
  DNS Inspect id not matched (inspect-dns-id-not-matched)                     66
  Interface is down (interface-down)                                         445
  Dropped pending packets in a closed socket (np-socket-closed)               86
Last clearing: Never
Flow drop:
  NAT failed (nat-failed)                                                     96
  Need to start IKE negotiation (need-ike)                               3345034
  Inspection failure (inspect-fail)                                           80
WI-GSMC-FORD-FW001# show version
Cisco Adaptive Security Appliance Software Version 8.2(3)
Device Manager Version 6.3(3)
Compiled on Fri 06-Aug-10 07:51 by builders
System image file is "disk0:/asa823-k8.bin"
Config file at boot was "startup-config"
WI-GSMC-FORD-FW001 up 15 days 22 hours
failover cluster up 29 days 22 hours
Hardware:   ASA5550, 4096 MB RAM, CPU Pentium 4 3000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0  : address is 0026.9986.988e, irq 9
1: Ext: GigabitEthernet0/1  : address is 0026.9986.988f, irq 9
2: Ext: GigabitEthernet0/2  : address is 0026.9986.9890, irq 9
3: Ext: GigabitEthernet0/3  : address is 0026.9986.9891, irq 9
4: Ext: Management0/0       : address is 0026.9986.988d, irq 11
5: Int: Internal-Data0/0    : address is 0000.0001.0002, irq 11
6: Int: Not used            : irq 5
7: Ext: GigabitEthernet1/0  : address is 0026.9926.00c4, irq 255
8: Ext: GigabitEthernet1/1  : address is 0026.9926.00c5, irq 255
9: Ext: GigabitEthernet1/2  : address is 0026.9926.00c6, irq 255
10: Ext: GigabitEthernet1/3  : address is 0026.9926.00c7, irq 255
11: Int: Internal-Data1/0    : address is 0000.0003.0002, irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : Unlimited
Maximum VLANs                  : 250
Inside Hosts                   : Unlimited
Failover                       : Active/Active
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
Security Contexts              : 2
GTP/GPRS                       : Disabled
SSL VPN Peers                  : 2
Total VPN Peers                : 5000
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has an ASA 5550 VPN Premium license.
Suspecting, If the box is with 5000 peer license then it should crack when it reaches  70%  ( ie 3500 tunnels )of the listed value
Best Regards,
Rajiv
Diego Armando C... Mon, 09/06/2010 - 15:29
  • Bronze, 100 points or more
Go ahead and restric the embro conns.  I do not think that is reponsable for the high cpu since you have a 5550 but it might help you.
the following command will help you to determine who has so many half onened connections if there is someone.
show local-host | include host|count/limit
There are
Active SA: 5763
Are you restricting your peers or you are using 0.0.0.0 in your pre-share key?
I hope it helps.
Jitendriya Athavale Mon, 09/06/2010 - 21:55
  • Cisco Employee,
firstly high cpu can be expected if you go anywhere near 5000 mark, sometimes depending on how much other traffic you have you can expect the performance to be affected even before the 5000 mark is reached
now if you feel you should have 3000 peers lets see why you have 5000 + phase 1 SA's, lets find out if we have duplicate SA's or are they some remote access users trying to make connection
try this
show cry isa sa | in
once you have an ip which has duplicate sa lets have more details about it
show vpn-sessiondb detail remote filter p-ipaddress or show vpn-sessiondb detail l2l filter
this will tell us about the session
also just a small query to understand your network, were any changes made to your network before you started seeing this, it can be anything like acquiring a new company or disbanding a company etc
just to understand why so much fluctuation in vpn sessions
