pre-share key showing as clear text in router configuration
Answered Question
Sep 6th, 2010
Hello Expert,
I using DMVPN to configure my tunnel between the Hub and spokes.
I discovered my pre-share key are shown in clear text when i do sh run config command.
How can i correct this.
crypto isakmp key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx address pp.pp.pp.11 (note i just edit the key for the purpose of this post)
Jomo
Correct Answer by Giuseppe Larosa about 6 years 7 months ago
Hello Jomo,
what IOS image is running on the hub ?
you can try to use
conf t
service password encryption
warning: but this will encrypt all passwords in configuration
check the syntax as I couldn't verify it.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 09/06/2010 - 13:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
rbglusers wrote:
Hello Expert,
Jomo
Jomo
See this document to answer your query -
Encrypt pre-shared keys in IOS
Jon
jomo frank Tue, 09/07/2010 - 09:58
hello jon,
I read the document as per link and i am able to encrypt the pre-share key on the spoke but not on the hub,
When I add a new pre-share for the any  spoke end point it is showing the clear text
A quick outline i have a hub router connect to around 7 spoke
I am using dmvpn to configure the vpn tunnels
as part of the ike policy i am adding unique pre-share key per spoke,as oppose to a single pre-share key for all.
I found only when i configure the 0.0.0.0 network i am able to get the encryption as showing below:-
IKE PRE-SHARE KEY CONFIGURATION ON THE HUB
crypto isakmp key thisatestkeyconfigurationnumber2 address ppp.xxx.rrr.2
crypto isakmp key thisatestkeyconfigurationnumber1 address eee.sss.www.17
crypto isakmp key #Zjq>eaRc2[KAsgj:`U7oBP\+o.qiZ-@ address 0.0.0.0 0.0.0.0
I am unsure how to move forward.
Correct Answer
Giuseppe Larosa Tue, 09/07/2010 - 13:42
  • Hall of Fame,
    Founding Member
Hello Jomo,
you can try to use
conf t
Hope to help
Giuseppe
jomo frank Wed, 09/08/2010 - 07:16
hello Giustar,
VERSION
This is the show version output of the router: show version
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:10 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
uptime is 7 weeks, 3 days, 15 hours, 6 minutes
System image file is "flash:c2800nm-advsecurityk9-mz.124-3i.bin"
>>>>   you can try to use
       conf t
This command is alredy on the router see subset of my running configuration below
router07#sh run
Building configuration...
Current configuration : 6769 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
Jomo
