high temperature...
Sep 6th, 2010
Hello Guys,
They told me to check a switch ws-2980G-A (I think it is very old model) because it was not working, executing some commands and watching that air sytem neither was not working I did realise that temperature was in 84Cº!!,.Aafter disconnect the device for some time and reconnect it it worked again, now I would like to know if the switch will continues working normal if the air system is fixed, or if the switch was damaged (how can i know?) for that high temperature, or if the switch needs to be changed due to switch is old.  any advise would be appreciated.
Reza Sharifi Mon, 09/06/2010 - 16:25
Keep it running and keep an eye on it and if the switch is running normal after a week or 2 then it is probably fine.  If you turn it on and see the temperature is high than you need to replace it.
Reza
Related Content
