6500 VSS crashed
Hi All
I was wondering if anyone was able to help with the following: I have a pair of 6500 in VSS mode, the active 6500 crashed and the second unit has taken over as expected. Now I am unable to SSH to the active VSS member. The switches are running 12.2(33)SXI3. I had thought maybe the crash was part of the problem, is there a tool on the Cisco site to see the bug that caused the crash, as this says it was a software forced crash.
%Software-forced reload
Breakpoint exception, CPU signal 23, PC = 0x42734E38
Traceback= 41BBD3FC 41BBF094 41BBF51C 41358338 41358324
Also I am seeing the following in the LOG:
SSH2 0: RSA_sign: private key not found
SSH2 0: signature creation failed, status -1
Regards MJ
Reza Sharifi Mon, 09/06/2010 - 15:56
  • Cisco Designated VIP,
    2017 LAN
Hi MJ,
There is well know bug in SXI3 with SSH key corruption and when the box in upgraded and/or crashed the SSH FQDN in lost.  I would open a TAC case immediately so Cisco can keep track of it.  If you have a lab and can test SXI4a test it and upgrade.
Reza
Reza Sharifi Mon, 09/06/2010 - 16:20
    2017 LAN
Hi MJ,
This is strictly my opinion, but to me safe harbor release does not proof anything.  All of these images are brand new and I have no idea how Cisco can make a code "safe harbor" when it is it only a few months old with limited use.    As matter of fact, at one point, a few months ago SXI2 was "safe harbor" but the next thing you know it was differed, because of major bug issues and crashes.
Here are a couple of know bugs in SXI3 that was resolved in SXI4 and 4a.
Reza
* CSCsh51293-Resolved in 12.2(33)SXI4
The Secure Shell server (SSH) implementation in Cisco IOS contains multiple vulnerabilities that allow unauthenticated users the ability to generate a spurious memory access error or, in certain cases, reload the device.
* CSCsg65318-Resolved in 12.2(33)SXI4
Symptoms: Malformed SSH version 2 packets may cause a memory leak.
Conditions: This symptom is observed on a Cisco platform configured for SSH version 2 after it has received malformed SSHv2 packets. The impact of this flaw is that the affected platform may operate in a degraded condition. Under rare circumstances it may reload to recover itself.
