Dot1x OPort Control & Quarantine VLAN
bradleyordner
Level 3
Level 3
I was wondering if it is possible to use Dot1X Port Control on a Wireless Network.
What we would like is when a user trys to authenticate with PEAP-MSCHAPV2, if they pass they are allowed access to the WLAN. If they fail authentication they are moved to a Quarantine VLAN.
Is this possible with configuration, like dot1x port control on a switch or do we need a NAC Appliance?
Thanks in advance,
Brad
George Stefanick
Yes, you can do something like you proposed without NAC. The question is what you mean by "Quarantine". The user would just get dumped in a hole until his logon was corrected. He wouldnt get a "deny" screen or anything pretty ....
