CWLMS + ACS user levels
Sep 6th, 2010
The integration of CWLMS 3.1 under Solaris 10, with ACS 4.2 (0) Build 124 Patch 9, was performed.
All the CW modules were applied (Register all installed applications with ACS).
Attached you will find the screen with the configuration after the integration (see image).
It is correct the local ciscoworks authorization?
Each user logged is always seen as help desk user, even when ACS is configured as system administration level.
Is any configuration missing in CW? or depend on the ACS configuration?
Thanks very much in advance
Joe Clarke Sat, 09/11/2010 - 17:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, this is not right.  Something is not working with ACS.  Post a screenshot of your Common Services > Server > Security > AAA Mode Setup screens.
