2 or more connected tunnels at RV082 through group VPN from same external IP?
Sep 6th, 2010
      Hi, i have configure and works well a group vpn at RV082, many different tunnels can be connected, but there is no respond when there is a connected tunnel with a pc (PC1) with external IP (x.x.x.x) and try to connect a pc from same LAN (PC2) to group VPN. PC1 and PC2 are on the same LAN with different LAN IP's and the same external IP. They use Netscreen Remote client from MS Windows XP. Thanks!!
Related Content
