Static route is not getting cleared from ASA
Sep 6th, 2010
I am running ASA version 7.2 (4)
I have seen that  there is a default ststic route in ASA pointing twards a next hop which i have already deleted from the no route command.
I have not find any bug related to that in IOS.
Your help is appreceiated.
abinjola Mon, 09/06/2010 - 23:42
Hi there,
There arent details mentioned in the description, but so far it looks it may be a RRI induced route.
Check the details mentioned in:
CSCsh49542  "static route may be created on ASA that cannot be removed" which is duplicate of CSCsf00564 fixed in 8.0.x
rupam_chakra1983 Tue, 09/07/2010 - 00:32
But the route is a default  route tht is enterred and lso the next hop is my load balancer.
Can RRI be the issue in this case
abinjola Tue, 09/07/2010 - 03:08
you need to check in show asp table routing , also check if RRI is enabled
