How to configure CE for port-based EoMPLS ?
Answered Question
Sep 7th, 2010
Hello!
Here is a scheme:
CE1-----PE1-------PE2----CE2
Assume, that PE1 and PE2 are MPLS-enabled and visible to each other.
CE1, CE2 - are Cisco switches
PE1, PE2 - are 7600 routers
I would like to transport several customers vlans through PE1-PE2 MPLS cloud.
For example, using port-based EoMPLS, typical interface towards CE will look like:
PE1# show run interface f8/48
interface FastEthernet8/48
no ip address
xconnect 75.0.78.1 1 encapsulation mpls
end
What configuration I should use on CE1,2 interfaces towards PE ? Just trunks ?
Thanks in advance.
Correct Answer by Atif Awan about 6 years 9 months ago
Yes configuring the CE interface as a trunk will allow you to carry the VLANs across the pseudowire. Keep the MTU requirements into consideration.
Atif
Overall Rating: 5 (1 ratings)
Correct Answer
Atif Awan Tue, 09/07/2010 - 01:15
  • Cisco Employee,
Atif
Alexander Demin Tue, 09/07/2010 - 01:36
Thanks!
As I understand the only feature that VPLS could add to this scheme is  multipointing ?
Atif Awan Tue, 09/07/2010 - 21:38
  • Cisco Employee,
Yes VPLS will provide you with multipoint capability, however, support for QinQ as VPLS AC will need to be verified on the respective PE devices.
Atif
