09-07-2010 12:18 AM - edited 03-16-2019 12:38 AM
my first node the Publisher is down and only one Subscriber is running of that cluster now.
1.Is it possible to get the CDR data to a Billing Application Server?
2. Will be written CDR data in that case?
I checked the Services and CDR Management, they seem to be ok.
Cisco CDR Repository Manager Running
Cisco CDR Agent Running
Cisco CAR Scheduler Running
Solved! Go to Solution.
09-07-2010 06:29 AM
Call detail records and call management records, when enabled, are collected by each subscriber and uploaded to the publisher periodically. During a period that the publisher is unreachable, the CDRs and CMRs are stored on the subscriber's local hard disk. When connectivity is re-established to the publisher, all outstanding CDRs are uploaded to the publisher, which stores the records in the CDR Analysis and Reporting (CAR) database.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/models.html#wp1044074
Above from SRND
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
09-07-2010 06:29 AM
Above from SRND
java
09-07-2010 11:52 PM
Yes this was helpful!
Thank you!
