PAP2T provisioning
Sep 7th, 2010
Currently we provision our customers' adaptors by providing each adaptor the address of a TFTP server as part of the DHCP response. The config files reside on the server but presently in unencrypted form. How can we encrypt these and still have the adaptor understand them? The documentation does give a couple of hints but is confusing and seems to assume an https solution, which isn't really appropriate given the TFTP solution we use (we could change, but it is an upheaval I would rather avoid - I'd rather simply provide encrypted files on the TFTP server).
Alberto Montilla Wed, 09/08/2010 - 04:38
  • Cisco Employee,
Dear Sir;
If you use tftp, you can encrypt them using e.g. the MAC address as the encryption key of the device. The provisioning guide (in the documentation section) provides information about how to accomplish it: basically you need to encrypt the file (using SPC) with the key (recommend MAC address as then you dont need to pass the key to the device), and then in the device profile rule, need to include the encryption key as a token. I recommend you have a look at the provisioning guide as it explains the mechanism.
Alberto
SomeRandomPerson Wed, 09/08/2010 - 06:45
Hi Alberto,
Thanks for your answer. By "SPC" you mean the Profile Compiler, right? We don't use that at present - can we use openssl as described in the provisioning guide and get the same behaviour/results?
I don't understand when you say at one point "basically you need to encrypt the file [...] with the key  (recommend MAC address as then you dont need to pass the key to the  device)" and then "in the device profile rule, need to include the encryption key as a  token". So if I use something like:
openssl enc –e –aes-256-cbc –k –in profile.xml –out profile.cfg
to encrypt each config file which then get placed on the TFTP server, do the adaptors need to be separately informed of the keys/passphrases or not?
Alberto Montilla Fri, 09/10/2010 - 10:28
  • Cisco Employee,
Dear Sir;
If the paraphrase is the MAC or serial number, it is not required as these are MACRO variables on the device. Check the provisioning guide for a full explanation about how to use MACROS.
Alberto
SomeRandomPerson Thu, 09/23/2010 - 06:51
I seem to have encrypted the file correctly (I can decrypt it using "openssl enc -d ..." as mentioned in the documentation), but the adaptor I am using to test this on is not showing the new values, so I'm not sure if it is not requesting the file from the TFTP server (that part is out of my hands, and there does not seem to be any log information anywhere) or if the adaptor cannot decrypt the file it fetches.
Is there any way to find out from the adaptor when it last tried to download a config file, why the fetch or decrypt might have failed, or anything like that? Or is there some way I can hand it the encrypted file "directly" so I know it gets it (that would at least tell me that if the changes still don't take then something in the encryption/decryption is incorrect)?
An additional point: how should the MAC address be formatted when used as the passphrase? For example if the MAC is 00:25:9C:6D:08:45 one could use that as the passphrase, or without the ":"s, or lowercase 00:25:9c:6d:08:45, or lower case without ":"s. Did I miss anything out?
The error is in the encryption string. This is because the unit can download the file but can't read it.
That's because the guide mentioned here in the "string" is wrong.
If you are using XML as a configtemplate and unix you can do this:
To encrypt a file you need to do two thing
1. zip the file using
qzip file.xml
2. encrypt the file using openssl
openssl enc -e -aes-256-cbc -k passkey -in file.xml.gz  -out file.cfg
This works as long as you place the correct value in Profile rule.(this downloads a lowercase macaddress file ex. 0000aaaabbbb.cfg)
[--key passkey]tftp://address/$MA.cfg
This only works with xml!!!
For plaintext configs you might want to use the SPC tool created by Cisco.
create the file and write this in a windows command window
spc --aes --ascii-key passkey file.txt file.cfg
If you want to be able to decrypt the files (if you are using a configenerator that also encrypts the files) i would recommend the use of XML.
Only thing you then have to do to decrypt the files are:
1.
openssl enc -d -aes-256-cbc -k passkey -in file.cfg -out file.xml.gz
2.
uncompress file.xml.gz
SomeRandomPerson Fri, 10/01/2010 - 01:23
What do you mean? What "string"?
We are.
Why? Why on earth would I need to compress it? Please stop trying to complicate matters.
That's exactly what I get - the file on the tftp server is named exactly as you said. Whether I should use this lower case value as the passphrase, uppercase, with or without the typical ":" separation characters seems to be completely unknown. I can confirm that 00259a6b01666 for example does not work, neither does 00259A6B01666. The config file is successfully retrieved from the tftp server, however.
I can do this on the command line. The problem occurs in "live" use when the adaptor itself tries to decrypt the config.
well.
When it comes to the "string" i just meant  the string of replies.
if you wonder why on earth you need to compile please ask linksys/cisco that question. That is what is written in the admin prov docs.
Yes. the unit recognizes the file when it decrypts the .cfg file. if it finds a txt file it opens it straight away.
But the xml files needs to be compressed to an archivel, dont know why. its just how it is.
SomeRandomPerson Sun, 10/03/2010 - 23:37
Odd. The Provisioning Guide I have says "The SPA configuration profile open format consists of a text file (with XML-like syntax), optionally
compressed using the gzip deflate algorithm (RFC1951), and further optionally encrypted" (my emphasis) and the examples don't seem to indicate a compressed file:
Example 2-8     Encrypting the Configuration Profile
# example encryption key = SecretPhrase1234
openssl enc –e –aes-256-cbc –k SecretPhrase1234 –in profile.xml –out profile.cfg
Still, I will try it out...
SomeRandomPerson Mon, 10/04/2010 - 04:53
No, just the MAC as suggested by Alberto. So I encrypt an XML config with (for example):
openssl enc -e -aes-256-cbc -k  00259c6d0845 -in 00259c6d0845.cfg -out 00259c6d0845.cfg
and can happily decrypt the resulting file on the command line as well, using
openssl enc -d -aes-256-cbc -k  00259c6d0845 -in 00259c6d0845.cfg
I am trying your suggestion of gzipping the config first, now, and will let you know what happens.
SomeRandomPerson Mon, 10/04/2010 - 07:48
No, doesn't work.
Edit: Wait. It's still trying to get the .cfg file...
I don't suppose there is any way of configuring things so that /ata_linksys_pap2t/$MA.cfg could be something like /ata_linksys_pap2t/$MA.xml.gz for one specific adaptor (for testing purposes), is there?
SomeRandomPerson Tue, 10/05/2010 - 00:33
We're using tftp, but we don't use spc, we create xml config files via our own software that fits in with the rest of our environment. Those files work fine, I'm now trying to add encryption to that to protect the customer information. Firmware version is 5.1.6(LS) apparently. You could try 00:25:9c:6d:08:45 if you want.
SomeRandomPerson Thu, 10/07/2010 - 06:56
Well I don't know what is wrong. I've tried using the MAC as the passphrase/encryption key as advised by Alberto, using both upper and lower case, with and without separating ":"s, and nothing seems to work.
i've created the files.Thos should work.
i've used these commands.
gzip 00259c6d0845.xml
openssl enc -e -aes-256-cbc -k 123456789 -in 00259c6d0845.xml.gz -out 00259c6d0845.cfg
in the specific ATA box set this as a profile rule:
[--key 123456789]tftp://addresstotftp/$MA.cfg
(change also these settings so the "download" goes faster
          -   3600 <-- set it to 30
          -   3600 <--set it to 30
     in the webgui)
btw.
i see that one of the files got renamed from                                               00259c6d0845.cfg to                                               00259c6d0845.cfg.zip
remember to rename the file back to .cfg
SomeRandomPerson Sun, 10/17/2010 - 23:51
Thanks, but if you read the rest of the thread, Alberto says you can use the MAC as the passphrase for en/decryption. I guess from your own experiences you found this wasn't true and that is why you are using the [--key 123456789]?
We basically have a number of config files, each "pointing" to the next. That is, init.cfg has e profile_rule_b  entry that points to ata_linksys_$PN.cfg, which in turn contains a profile_rule_c entry pointing to $MA.cfg. Even if I can somehow add something to the profile_rule_c entry to indicate the passphrase, that does not seem any more secure than leaving the file unencrypted on the tftp server (since the previous files are unencrypted and would have the passphrase in cleartext in them).
This entire area seems rather shambolic on the part of Linksys.
Alberto Montilla Mon, 10/18/2010 - 03:16
  • Cisco Employee,
Dear Sirs;
In the case of using the MAC, can you please let me know the commands as well as the profile rule you are using?
This should work properly.
Regards;
Alberto
SomeRandomPerson Mon, 10/18/2010 - 23:29
openssl enc -e -aes-256-cbc -k 00259C010203 -in 00259C010203.xml.gz -out 00259C010203.xml.gz
The profile decrypts perfectly with
openssl enc -d -aes-256-cbc -k 00259C010203 -in 00259C010203.xml.gz.openssl -out 00259C010203.xml.gz
The file is definitely being requested from the TFTP server.
SomeRandomPerson Tue, 10/19/2010 - 03:52
[email protected]
Is this the command you are using as a profile rule on the unit?
Yes. In another config file on the tftp server actually.
Remember to add [--key 00259C01020] in front of the URL.
[--key 00259C01020]/ata_linksys_pap2t/$MA.cfg
No, because:
amontill wrote:
you can encrypt them using e.g. the MAC address as the encryption key of the device. [...] basically you need to encrypt the file (using SPC) with the key (recommend MAC address as then you dont need to pass the key to the device), and then in the device profile rule, need to include the encryption key as a token.
(My emphasis)
Admittedly, that's not very clear, but it was clarified a couple of posts later:
Related Content
