SPA2102 : Fax no answer incoming call
Sep 7th, 2010
I configure an SPA2102 for a fax (HP 2840 Multifonction Printer).
I upgrade SPA2102 to 5.2.10 firmware
When I send Fax, all is ok
But when I want receive a fax, the fax machine doesn't answer (no ring). I connect an analog phone after the Fax for test, and it correctly ring...
Does anyone can help me...
Best regards,
nmerian Tue, 09/07/2010 - 09:07
I finish to find the answer by myself : I change the value of the "Ring Frequency" parameter (20 by default) to 35. And now It work fine.
On the SPA2102 : Voice / Regional / Ring and Call Waiting Tone Spec / Ring Frequency
falcontech Sat, 02/04/2012 - 13:21
We have a similar problem with the spa2102 but it appears the fax answers but during the receive it fails with a communication error. We can send faxes no problem we can't receive.
