Multiple networks in cryptomap not working.
Answered Question
Sep 7th, 2010
Hi.
I have 1 ASA 5505 at a site, and a 5510 on another site.. on the 5510 i have 4 subnets on diferent interfaces.
I have a vpn between the 2 ASA´s , and on the 5510 the local net is defined as all of the subnets i want to have access to,
on the 5505 i have the subnets in the remote net.
But when i want to acces the networks over the vpn.. it wont..
The connection is up, but under the ADSM monitor, vpn connections, and details. i can only see one of the nets from the crypto map.
and i can only ping on that net.
If i do a packet trace, on the net in the details. i can see it routes it over vpn, if i try one of the other nets. it dont route over vpn.
object-group network DM_INLINE_NETWORK_1
network-object 172.26.1.0 255.255.255.0
network-object 172.26.2.0 255.255.255.0
network-object 172.28.0.0 255.255.248.0
network-object 192.168.0.0 255.255.255.0
access-list whatsup_nat0_outbound extended permit ip 192.168.173.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_4_cryptomap extended permit ip 192.168.173.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
Another question.
How do i allow pinging the interface addresse from the other interfaces.. ie over the interface.
And the last one..
Is it possible to do a Static nat from one interface f.eks Int1 192.168.100.10 -> Int2 ->10.10.10.10, and then Connect to Int1 192.168.100.10 from int3 20.20.20.20 ???
/Rene
Correct Answer by Nagaraja Thanthry about 6 years 5 months ago
The reason it is not working is because of the NAT-0 rule you have
configured.
object-group network DM_INLINE_NETWORK_16
network-object nitron 255.255.255.0
network-object dmz_zone 255.255.255.0
access-list MPLS_nat0_outbound extended permit ip 172.26.0.0 255.255.252.0
object-group DM_INLINE_NETWORK_16
nat (MPLS) 0 access-list MPLS_nat0_outbound
From the above lines, you can see that 172.26.0.0/22 goes un-natted to
192.168.0.0/24 subnet (inside). NONAT rule takes precedence over static NAT.
So, you are not able to connect using 192.168.0.199 address. Please insert
the following lines into your configuration:
access-list MPLS_nat0_outbound line 1 deny ip host 172.26.2.5 any
access-list pnat1 permit ip host 172.26.2.5 any
access-list pnat2 permit ip host 172.26.2.5 any
no static (MPLS,Inside) 192.168.0.199 172.26.2.5 netmask 255.255.255.255
static (MPLS,Inside) 192.168.0.199 access-list pnat1
static (MPLS,Inside) 172.26.2.5 access-list pnat2
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Tue, 09/07/2010 - 05:49
For the first question, the problem seems to be with your NAT-0
configuration.
In order for you to be able to communicate with all the networks behind the
remote ASA, you need to enable NAT-0 for all remote subnets.
For the second question, you can ping from the remote networks (via VPN) to
one interface of the local firewall (typically inside interface) by using
the following command:
management-access "interface name"
ex:
management-access inside
As far as the question about static NAT is concerned, if I understand you
correctly, you are looking to statically NAT a host on INT1 to another IP
when going to INT2. But you would like to access the same host with its
original IP from INT3. That is absolutely possible. But, you need to make
sure that you are configuring an identity NAT rule between INT1 and INT3.
static (int1,int2) 10.10.10.10 192.168.100.10 netmask 255.255.255.255
static (int1,int3) 192.168.100.10 192.168.100.10 netmask 255.255.255.255
Hope this helps.
NT
ReneRasmussen Tue, 09/07/2010 - 05:59
Hi Nagaraja.
Thanks.
Then "access-list whatsup_nat0_outbound extended permit ip 192.168.173.0 255.255.255.0 object-group DM_INLINE_NETWORK_1"
Worked perfect.
So if i understand.. the nat0 outbound list is decideing what not to nat thru the "normal" global nat to outside.. and then it goes thru vpn.
As for the static nat.. what i have today is a asa with 3 interfaces.. i have added a 4, an mpls net.. i want to move one server fron the INT1 to this Mpls net.. and not have any clients notice that i have moved it. so im doing a static nat from the original ip to the new on the mpls net.
only problem is that when trying to connect to this static nat addresse, i  get no connection.
i want all clients from all interfaces, to still connect to the old ip (which im static nattting to the new ip)
/Rene
ReneRasmussen Tue, 09/07/2010 - 06:17
access-list MPLS_nat0_outbound extended permit ip 172.26.0.0 255.255.252.0 object-group DM_INLINE_NETWORK_16
nat (MPLS) 1 172.26.0.0 255.255.252.0
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 1 192.168.0.0 255.255.255.0
nat (dmzzone) 0 access-list dmzzone_nat0_outbound
nat (dmzzone) 0 dmz_zone 255.255.255.0
nat (vms) 0 access-list vms_nat0_outbound
nat (pak) 0 access-list pak_nat0_outbound
i want the 192.168.0.199 to be accesible from all nets.. (even tho i is nattet to 172.26.2.5)
and i would also like to be able to connect to 172.26.2.5 (not nattet) so i would both use routet and nattet. So transition to new net can be made over time.
/Rene
Correct Answer
Nagaraja Thanthry Tue, 09/07/2010 - 06:27
configured.
Hope this helps.
NT
ReneRasmussen Tue, 09/07/2010 - 06:43
So for all ips i want nattet (when there is a 0 nat)
i do a deny, and then policy nat
for x to y
and for x to x.
Great..
Many Thanks for the great help.
