IP Phone (CP-7942G) - License option
Sep 7th, 2010
Hi everyone,
I want to order cisco ip phone(cp-7942G), 50 qty, i was told to install a call manager RTU license before this order can go through from the configuration tool(DCT). though we have some call manager and servers like MCS-7825-I4-IPC1 and MCS-7845-I3-CCE1 coming with this order.
which option of license should i select for the IP phone:
(a)     SW-CCM-UL-7942          CUCM 3.x or 4.x RTU license for single IP Phone 7942
OR
(b)     SW-CCME-UL-7942     Communication manager express license for one 7942g phone
please which license should i select?
thanks
Rob Huffman Tue, 09/07/2010 - 05:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Samson,
It doesn't seem like either of those Licenses that were listed are
correct if you are going to be installing "full blown" Communications
Manager
The first License listed is for "older" Callmanager 3.x and 4.x builds and
the second License is for Communications Manager Express.
In the 6.x and early 7.x Communications Manager builds the phone requires
a set amount of DLU's or Device License Units. In your case the 7942 requires
4 DLU's. You would need;
4 - LIC-CM-DL-10
Unified CM Device License - 10 units x4
Cheers!
Rob
sajith.kumar Tue, 09/07/2010 - 06:01
Hi rob,
thanks for your reply.. i was using the dynamic configurator tool for this .. but without selecting either of the two options(licence). the configurator will not check/go through.
thanks
rahman001 Tue, 09/07/2010 - 06:06
hi rob,
thanks for your reply..i was using the dynamic configurator tool for this...but without selecting either of the two options(license). the configurator will not go through/check.
thanks
