Support tools required for ICM 7.5
Answered Question
Sep 7th, 2010
Hello Team,
We are upgrading a customer from ICM 6 to ICM 7.5. Is support tools a required  application for ICM 7.5?This is a technical question - not sales or ordering related - I just need to  confirm if we upgrade to ICM 7.5, support tools is not required and there will  not be issues if we do not install it.
David
Correct Answer by david.macias about 6 years 5 months ago
Yeah the verbiage is misleading, don't worry about support tools server, do your upgrade and after you're done I recommend (and it sounds like Geoff does too) to put it in place.  You will need both a server for it and to ensure the client is running on all the ICM components.
david
Correct Answer by geoff@hp.com about 6 years 5 months ago
If you are upgrading from ICM 6.x to ICM 7.5 I can guarantee you are doing a tech refresh and a server from the old hardware set is a perfect candidate for Support Tools. It takes all of 10 minutes to install and configure. You could easily use make use of it.
Geoff
It's not required, it just makes life easier.  Heck you can install it on any old computer.
david
Overall Rating: 5 (3 ratings)
Correct Answer
david.macias Tue, 09/07/2010 - 11:07
david
Correct Answer
geoff@hp.com Tue, 09/07/2010 - 11:10
Geoff
Correct Answer
david.macias Tue, 09/07/2010 - 12:02
david
