09-07-2010 08:10 AM
I received the following error message when trying to deploy the changes to the device:
CEDT0031: no command is available to download for the device X.X.X.X. REmove the device from the job and try again.
Solved! Go to Solution.
09-11-2010 05:44 PM
You can't do that. Instead, just remove "aaa new-model" from the config then try to deploy it. Alternatively, you can try "merge mode," but that will send the whole config back to the device.
09-07-2010 09:40 PM
What mode are you selecting (merge or overwrite)? What exactly was changed in the configuration?
09-08-2010 07:02 AM
overwrite command. I was trying " no aaa new-model" command.
09-11-2010 05:44 PM
