Remove "Bell" from phone
Answered Question
Sep 7th, 2010
I cannot for the life of me figure out how to remove the "Alarm bell" that appears on a phone so I can reconfigure it for another user. I'm having a brain slip, usual day for me. anyone have an idea?
Correct Answer by Rob Huffman about 6 years 8 months ago
Correct Answer by Jonathan Schulenberg about 6 years 8 months ago
Is this in a set of four icons? If yes, then this is IPMA and is triggered by the End User assigned to that phone having a Manager Configuration assigned. You have to use the Related Tasks dropdown from the End User Configuration page to get to it.
Overall Rating: 5 (2 ratings)
Rob Huffman Tue, 09/07/2010 - 10:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey John,
We're both having one of those days
Can you expand on what you mean by "Alarm bell" I'm not sure what reference or
context this fits in to?
Cheers!
Rob
j.mccartney Tue, 09/07/2010 - 18:53
Hi Rob,
There is a icon of a "bell" on the lower left side of the screen on a 7942 phone. I thought it had to do ipma manager but cannot find anything on the web about it.Although when I press DND it places a zero with a line through it to represent "not". Any idea what seeting removes this?
Thanks.
John
Correct Answer
Jonathan Schulenberg Wed, 09/08/2010 - 05:20
    2017 IP Telephony
j.mccartney Wed, 09/08/2010 - 07:39
Thanks for the help Rob. The problem was the user was removed from AD a while ago and thus not showing up in user account. I tried to add him back to AD and update LDAP etc.. What I had to do was remove the phone all together and rebuild it from scratch, no more bell!!
Thanks.
John
