System Numbering Question
Answered Question
Sep 7th, 2010
I typically use 1XXXX for system numbers, but I have a situation where we need to use [1-8]XXX for user extensions.  I don't want to simply lower the inter-digit timeout and use 1XXX.  So, I see my obvious option as:
  • Use 1[235]XXX for system numbers and free up some ranges for user extensions.
However, I'd like to free up all 1XXX for user extensions.  Will using 0XXXX for System Numbering cause any issues other than with inter-digit timeout with '0' for operator?
Correct Answer by iptuser55 about 6 years 6 months ago
You should be fine, it will view it as 0100. I tend to use a mixture of a dedicated System Partition and very long system numbers for future proof in case we ever have DN`s beginning with 0 in your case . So if you were to use 0 as a system prefix then make it 0000xxxxx so at least you will only make use of one potential DDI, DID number of 0000 obviously any other number with 000x will rely on the EOD timeout but at least you future proof
Overall Rating: 4.7 (3 ratings)
Jaime Valencia Tue, 09/07/2010 - 10:59
  • Cisco Employee,
  • Hall of Fame,
    2011
There is no real difference if you use 0 or 1 (or anything between 0-9 for that matter)
CUCM has no special significance for any digit.
If you currently only use 0 for the operator then that would be the only DN affected.
You can tell users they can press # to expedite the call to the operator.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Aaron Dhiman Tue, 09/07/2010 - 11:57
And, as far as you know, no other apps like Unity Connection/Unity, CER/UCCX CTI Ports, etc, would have issues with their numbers beginning with a '0'?  For instance, when configuring the range of numbers for CTI Ports in UCCX, if we start with 0100, will it interpret it properly, or as 100?
Correct Answer
iptuser55 Wed, 09/08/2010 - 04:01
  • Silver, 250 points or more
Jonathan Schulenberg Wed, 09/08/2010 - 05:16
  • Cisco Designated VIP,
    2017 IP Telephony
There is a known issue with leading-zero directory numbers and Auto Registration. Do not use a DN range starting with zero for your auto-registration DN range.
