CUBAC and directory information
Sep 7th, 2010
Does anybody know a way to have mobile numbers show in the directory information on CUBAC, i have a system integrated with UCM and i can see extension users that have been synced across via axl. I noticed the external directory option on the CUBAC can this be used ?
dw
Jaime Valencia Wed, 09/08/2010 - 07:35
Yes,
Tthe directory is imported from the CUCM. Users can then add additional  information in the fields not sync'd from CUCM - such as location, job  title etc. If they add any external numbers - i.e. cellphone - they'll  show up in the external directory
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
mattcalderon Thu, 11/03/2011 - 06:21
with CUBAC 8.6 you can do LDAP sync. Can we then sync other numbers - ie telephone number field?
jamgale Tue, 02/14/2012 - 13:15
With CUBAC it is not possible to change the default field mappings or add any of you own, to do this you need to use CUEAC.
