Giuseppe Larosa Wed, 09/08/2010 - 12:40
  • Hall of Fame,
    Founding Member
Hello Ali,
in Channel Associated Signalling the supervisory signalling travels on channel 16 in a  single DS0 64 kbps channel.
However, signalling is sampled like the audio signalling.
In PRI a DS 0 channel is dedicated for framing and another DS0 for signalling (D channel) and it carries supervisory information for all B DS0 channels.
The difference is that signalling is carried within small packets in LAPD frames and this provides some advantages.
PRI is typically used with ISDN that requires a signalling plane that is implemented over the D channel to perform call setup and to provide additional services like hold, call transfer and so on.
PRI is an example of CCS = common channel signalling
see
http://www.asteriskguru.com/tutorials/e1t1.html
Hope to help
Giuseppe
Related Content
