Calls with "Unknown Number" drop with CUCM 7
Answered Question
Sep 7th, 2010
I have a CUCM 7 system setup with a centralized model.  2 Gateways using FXO on each gateway.  The 2 sites are connected via IPSec VPN.  When a call comes in from a number that has CallerID blocked, it manifests as "Unknown Number" on the IP Phone.  Al phones are 7970G.  Then after a brief period of time, the call is dropped.  This happens to calls coming in on either gateway, either the local gateway to the CUCM or the remote gateway.  The only calls that are dropped are those with the "Unknown Number"  all other calls process fine.  Is there something in the Service parameters that would affect this?  Or a setting on the h.323 gateways?  Any suggestions are appreciated.
Correct Answer by dksingh about 6 years 4 months ago
Its the GW that initiates the call drop 15 secs after it connects by sending h225 RLC with cause41 (temp failure)
Sep 15 20:23:55.194: //1673/F481FAD38AE6/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x66E0B7FC, Call Id=1673
Reason seems to be that h245 msgs TCS/MSD from GW are not responded by the CCM.
Strange that it happens only for calls with no CLID.
Can u share your GW config ?
Also CCM version and If the checkbox for "Wait for far end TCS" on CUCM H.323 GW config
page is checked or unchecked?
Thanks.
DK
Hello again!
You can hardcode CLID info using following CLI which will be
used for calls when telco does not deliver a name/num:
voice-port x/y/z
  station-id number 123456
  station-id name From Outside
  caller-id enable
If the issue persists, please grab following for one failed call:
deb vpm sig
deb voip ccapi inout
deb h225 asn1
deb h245 asn1
Pl. run the debugs during low traffic/maintenance as these are pretty verbose.
Thanks.
DK
Hmm...not aware of any existing issue or setting as such but curious
- how long before such call drops ? Is it same duration in all/most cases?
- are u sure its just the calls with unknown number and not other calls with valid CLID?
- any reports of unknown call staying up and not dropping ?
- have u tried spoofing calline name/number (station-id name | number CLI under FXO voice-port) to see the behavior ?
- any debugs or CCM traces collected ?
Thanks!
DK
Overall Rating: 5 (3 ratings)
Correct Answer
dksingh Tue, 09/14/2010 - 11:31
Thanks!
DK
fieryhail Tue, 09/14/2010 - 12:32
Thanks for the response.  I'm quite mystified by this as well.  To answer your questions as best I can, it is appx. 25-30 seconds from the time the call comes into the h.323 gateway from the PSTN that the call is dropped.  Yes, it is the same duration in all cases.  From my understanding, it is ONLY calls with unknown CLID that are dropped, none with a valid CLID are dropped.  Yes, there have been some reports from users (rare but some) of Unknown calls staying live without dropping, however, no concrete data can be compiled as to who the callers are.
In response to "have u tried spoofing calline name/number (station-id name | number CLI under FXO voice-port) to see the behavior ?"
I'm not sure exactly what you mean.  If you could explain more I'll either try it or let you know if I have.
No CCM traces collected as of yet, I don't see anything wrong with the debugs I've done on the router, although if you have specific ones for me to use I'll be happy to.  Thank you again for your response.
Correct Answer
dksingh Tue, 09/14/2010 - 12:38
Hello again!
voice-port x/y/z
  caller-id enable
deb vpm sig
deb h225 asn1
deb h245 asn1
Thanks.
DK
fieryhail Tue, 09/14/2010 - 13:17
Thank you for your suggestions, I will try them later, after 5:30pm EST, that's when things calm down a bit.  I'll keep you updated.
fieryhail Wed, 09/15/2010 - 14:21
Sorry for the delay, here are the results.  I did try spoofing the CLID at the gateway, no difference.  The call drops regardless however it does show the "spoofed" settings so that must be working properly.  Today I isolated one of the FXO ports by temporarily removing it from the trunk group and setting the "connection plar opx" statement to the DN of a user in CUCM directly (1007). I tried an incoming call from a normal, unrestricted CLID number and the call came through, stayed on the call for appx. 4 minutes with no issue.  Then called from a restricted CLID number (cell phone) and it rang the DN1007 IP Phone perfectly, showing "Unknown Number" and when I answered it, the call would stay live for 15 seconds.  I disabled all other debug on the gateway with the exception of what you reccommended and copied the debug results for this call to a text file which I've attached to this post.  To be honest, a lot of the debug data doesn't make much sense to me, but I hope it can help!  Once again, any suggestions are greatly welcome.  I do believe at this point the issue is isolated to the h.323/FXO gateway, not CUCM.  Thanks again for any advice!
Correct Answer
dksingh Wed, 09/15/2010 - 15:11
Thanks.
DK
fieryhail Thu, 09/16/2010 - 10:45
Thank you for your response.  The TCS is checked on both gateways in the CUCM.  Both gateways are configured identically as well.  FXO, etc.  As far as my config for the gateways, here it is:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g723r63
codec preference 4 g726r16
voice-port 1/0/0
trunk-group POTS2
no battery-reversal
input gain 10
echo-cancel suppressor
no comfort-noise
timing hookflash-out 50
connection plar opx 1201
threshold noise -90
caller-id enable
voice-port 1/0/1
trunk-group POTS2
no battery-reversal
input gain 10
no comfort-noise
threshold noise -90
caller-id enable
voice-port 1/1/0
trunk-group POTS2
no battery-reversal
input gain 10
no comfort-noise
threshold noise -90
caller-id enable
fieryhail Thu, 09/16/2010 - 11:09
Update, I unchecked the "Wait for far h.245 TCS on both gateways in CUCM, and had a test call placed from a cell phone that as verified as "Unknown Caller" and dropped consistently after 15-30 seconds.  With that checkbox unchecked the call stayed live until it was disconnected properly from the cell phone, I had the call left live for 90 seconds.  It appears that made all the difference.  I am extremely grateful for your knowledgeable assistance sir.  My sincere gratitude!
