Tomas De Leon Tue, 09/07/2010 - 20:56
Is the Presentation a DMD Presentation?
Is the Presentation & Playlist going to be stored locally on the DMP or
remotely on the DMM?
These questions are important in determining the steps to
perform.
But the easiest solution is creating a nested playlist
within a Master DMD Presentation.  You use the
Child Presentation URL address in the Master Presentation
playlist.
Cheers!
T.
semuthu.cisco Tue, 09/07/2010 - 21:15
Thank for the quick reply .
Yes its a DMD presentaion and if the procedure vary from playing from the DMP and from the DMM remotely, can you please describe the both .
Tomas De Leon Wed, 09/08/2010 - 07:29
semuthu,
the procedure is the same but how you find the URL is a little
different.
Remote Asset:
- simply instruct the DMP to play the remote DMD presentation and then go to the
DMP and look at the start URL.  Copy that URL into your Master DMD Playlist.
- repeat the process for mulitple remote DMD presentations that you want to put in
a playlist.
Local Asset:
- simply use the DMS-CD package and deploy to the DMP.  The DMM will auto
generate a GO TO URL in the advanced tasks for the DMD presentation.  Find
the GO TO URL for the appropriate DMD prezo and copy the URL to your Master
DMD Playlist.
- Repeat the process as necessary.
Note:  I have already provided you detailed steps for this method on one of your
previous posts. 09/06/2010
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
