09-07-2010 09:05 PM - edited 03-16-2019 12:40 AM
I am looking for some help on setting up a Automated Attendent on CME & CUE.
I have configured the dial-peer with the pilot number and used the GUI on CUE for setting up the prompts.
I am confused on what else needs done. I am looking for a guide on the complete process of setting an AA up and help working through my configuration.
Solved! Go to Solution.
09-07-2010 09:42 PM
You can find information from CUE Maintain and Operate Guides:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_maintenance_guides_list.html
Configuring Auto Attendants:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/5AAttnd.html
CUE Guide to Writing and Editing Scripts:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/administrator/script/edover.html
GUI Admin:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/administrator/GUI/ch1over.html
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
09-08-2010 10:06 PM
You would like to check this link too:
In the Unity Express Utilities you can download de CUE Editor so you can create your scripts, and also you can find some example scripts.
Gabriel.
09-07-2010 09:18 PM
Joe,
Take a look here: http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00803f82eb.shtml
The guide is a little older but the menus likely are very close. You may also look for the 8.0 version-specific guide on Cisco.
Hailey
Please rate helpful posts!
09-07-2010 09:42 PM
GUI Admin:
Kind regards,
- Adrian.
09-08-2010 10:06 PM
Gabriel.
