Initial Configuration for Cisco Voice Setup with Licensing
Sep 8th, 2010
Dear Experts,
My Scenario is:
I want to connect two offices A & B for voip solution.
1) Office A has Cisco router 2811 and a Pbx which is connected with E1 card installed in Cisco Router and the pbx supports 150 users
2) Office B has Cisco rotuer 2811 and is connected a Pbx which  is connected with E1 card installed in Cisco Router and the Pbx supports 50 users
I want to connect the pbx of both offices so that people from one office people could call to people to the other office over voip.
My questions are
1) Do i need a T1/E1 line from my ISP for this scenario? or only T1/E1 interface will do the job which is currently being used to only connect the pbx with the router?
2) What sort of license i need in order to install CME (Please note i will only be installing soft phones on maximum of 10 users)
3) Can i buy Cisco License online from any where in the world?
Please correct my scenario if i am wrong and advise with your expertise.
Thanks in Advance
Salman
dksingh Tue, 09/14/2010 - 13:00
  • Cisco Employee,
Hello there!
You don't really need any additional T1/E1 modules if you already have some sort
of IP WAN connectivity between the two sites/routers.
You should be able to create voip and pots dialpeers on both routers according to your
dialplan and send calls between the two sides using h323/sip. Pl. checkout info on IOS dialpeers at:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html
On ISRs the CME license is paper based and a SMALL one should suffice for your purpose.
Checkout Table3 for part#:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/prod_bulletin0900aecd8067e12c.pdf
Do you have a local reseller or Cisco Account contact you can get in touch with for procuring the licenses?
Hope this helps...
DK
