Frame Realy with EIGRP Routing and route -map?
Sep 8th, 2010
Hi ,
R1 is Router is connected to Frame relay is connect to two Router R2 and R3 with serial with EIGRP 37 and its working fine.
R2 and R3 Also connected via fast Ethernet.
R3 have loopback connected with 4.4.4.4 and R1 is connected with 1.1.1.1 Loopback0
R3 can 4.4.4.4 ping via serial interface directly to any network but now I did route map on R3 (4.4.4.4 is ping to go via FE0/0 7.7.7.7).
access-list 101 permit ip host 4.4.4.4 host 1.1.1.1
route-map test permit 10
match ip address 101
set interface FastEthernet0/0
I want to do ping to 1.1.1.1 on R1 with source 4.4.4.4 . RTO not able to ping routing is ok.
In debing show below error:
Sep  8 12:21:15.988: IP: s=4.4.4.4 (local), d=1.1.1.1 (FastEthernet0/0), len 100, encapsulation failed
Please help to resolve..
Lei Tian Wed, 09/08/2010 - 05:40
Hi Abhinay,
Change the route-map to set ip next-hop, see if that helps.
HTH,
Lei Tian
