simultaneous usage of both external & internal DHCP servers on one controller
Answered Question
Sep 8th, 2010
I have a WLC controller configured to use external DHCP server. Is it possible to use an internal DHCP server for another pool (external network) on a different physical interface, dynamic interface etc?
Thanks in advance
Correct Answer by Surendra BG about 6 years 4 months ago
create a SVI on the switch and configure the corresponding internal pool on the WLC.. this will do it.... make sure we are mapping the WLANs correctly..
Surendra
Overall Rating: 5 (1 ratings)
Correct Answer
Surendra BG Fri, 09/17/2010 - 00:35
Surendra
davy.timmermans Fri, 09/17/2010 - 02:53
if you want to use an external server: fill in the external DHCP IP in at the corresponding interface
if you want to use an internal server: fill in the management IP of the WLC
Mariya Telitsina Fri, 09/17/2010 - 03:16
the thing was about using them both at the same time )
have already cleared that out. thanks.
Trending Topics - Security & Network
