CCM 6.1.2.1000-13 Extension Mobility
Sep 8th, 2010
I have 2 servers running CCM 6.1.2.1000-13 on 2 sites both point back to the main server for Extension Mobility.
Any new phones that are configured for the remote site fail to show the service Login/logout display correctly, display is blank once the user enter the service tab, if the phone is returned to the main site and setup for the main site device pool the EM works.
I hve not done a restarted both servers service for the EM but still get the same problem.
As we run 24/7 I am unable to do a restart on the servers.
Jonathan Schulenberg Wed, 09/08/2010 - 04:20
  • Cisco Designated VIP,
    2017 IP Telephony
The phone is doing a standard HTTP GET for that URL.
What happens if you hit that URL from a PC at either of these remote sites? Do you get an XML response? If you do a packet capture of the phone doing it, does it also get a valid XML response? If it doesn't, what does a packet capture of the phone requesting the URL from the server's perspective show? If it shows it sending the response document you may have a firewall, WAN accelorator, or other layer seven issue present.
andymck10 Fri, 09/10/2010 - 01:21
Thanks for the pointer, URL works ok from PC.
Rebooted main server and error still showing , after reboot of the remote server the problem has now cleared. But has thrown up a problem with the DHCP ranges.
Something to work on over the weekend.
