LMS 3.2 : DCR Server is down or inaccessible
Answered Question
Sep 8th, 2010
Correct Answer by Martin Ermel about 6 years 5 months ago
is it possible that your system locales are set to french ?
this would be not supported. You need to set system locale and the default user locale to US-English.
according to this line it seems that your certificate has expired:
ERROR: Certificate Date Invalid
java.security.cert.CertificateExpiredException: NotAfter: Sun Aug 29 13:04:52 CEST 2010
I am not sure if it is possible to generate a new self-signed certificate here when DCRServer is down:
CS > Server > Security > Single-Server Management > Certificate Setup
give it a try...
If not I assume this methode Joe gave a while ago is still valid:
Do the following:
* net stop crmdmgtd
* cd NMSROOT\MDC\Apache\conf\ssl
* del server.*
* NMSROOT\bin\perl ConfigSSL.pl -disable
* NMSROOT\bin\perl ConfigSSL.pl -enable
This last step will prompt you to enter all of your cert info.  Once that is done, you have a choice.  If you want to run with SSL enabled, you will need to re-run:
If you do not want to run with SSL enabled, then simply rest5art dmgtd:
    net start crmdmgtd
Note: NMSROOT is the path into which you have installed CiscoWorks.  By default, this is C:\PROGRA~1\CSCOpx.
Overall Rating: 5 (2 ratings)
Joel Monge Wed, 09/08/2010 - 08:48
If you are on Windows, go to Start and click on 'Run...'. Type in services.msc and make sure you have the following services set like this:
CiscoWorks ANI database engine: Manual
CiscoWorks Daemon Manager: Automatic
CiscoWorks RME NG database engine: Manual
CiscoWorks Tomcat Servlet Engine: Manual
CiscoWorks Web Server: Manual
CWCS Cmf database engine: Manual
CWCS rsh/rcp service: Automatic
CWCS syslog service: Automatic
CWCS tftp service: Automatic
DFM dfmEpm database engine: Manual
DFM dfmFh database engine: Manual
DFM dfmInv database engine: Manual
If any of these are different, change them and reboot.  If problem remains, post a full pdshow output.
Joel Monge Thu, 09/09/2010 - 06:58
Post the dcr.log and DCRServer.log.  Is there any change on this server you can correlate to this problem?  Was there anything new installed?
korrigan29 Thu, 09/09/2010 - 08:01
I don't know if anything new has been installed, I don't manage the system, but only CiscoWorks software.
I'll try to have this information if you need it.
Correct Answer
Martin Ermel Thu, 09/09/2010 - 08:21
give it a try...
Do the following:
* net stop crmdmgtd
* del server.*
    net start crmdmgtd
korrigan29 Mon, 09/13/2010 - 01:32
Thank you. It's OK now.
I tried what you told me :
"I am not sure if it is possible to generate a new self-signed certificate here when DCRServer is down:
give it a try..."
It works. Thanks a lot.
