ASA 5540 mem upgrade Should I remove existing memory
Answered Question
Sep 8th, 2010
Currently running 1GB in ASA 5540
I have purchased ASA-5540-MEM-2GB upgrade kit
Should I leave the existing 1 GB installed and install the 2 GB kit
or should I remove existing 1 GB and install the 2 GB?
Correct Answer by Nagaraja Thanthry about 6 years 4 months ago
Remove the 1GB. It has been observed that with the old memory in there, the
device might get into a continuous boot cycle.
NT
Overall Rating: 5 (2 ratings)
Correct Answer
Nagaraja Thanthry Wed, 09/08/2010 - 06:54
NT
thomuff Wed, 09/08/2010 - 07:29
Thanks for the reply. I will rate and update once I have installed the memory.
thomuff Thu, 09/09/2010 - 13:41
I marked it as Correct answer and extreme helpful because 1) No issues 2) Multiple source provided same answer.
