Cisco RAS dialin with DDR dialout
Dear experts,
Please be so kind and take a look at my configurations and problem.
I need to configure Cisco 2811 (modem pvdm2-36D, E1 PRI) as RAS for dialin and dialout DDR to 250 remote locations (analog modems) with different usernames and passwords.
I managed to configure dialin where authentication is done via radius and that works flawless but I'm confused with how to configure DDR on same device.
Remote locations authenticate with radius and get their static IP addressess via radius too.
Please give me suggestions/examples.
My current configuration:
card type e1 1
aaa new-model
aaa authentication ppp default group radius local
aaa authorization network default group radius
aaa session-id common
clock timezone UTC1 1
clock summer-time MET-DST recurring last Sun Mar 2:00 last Sun Oct 2:00
network-clock-participate slot 1
network-clock-select 1 E1 1/0
modem country v12 e1-default
no ip source-route
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.1.125 255.255.255.0
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
isdn incoming-voice modem
no cdp enable
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
async mode interactive
ppp authentication pap
group-range 0/322 0/357
ip route 172.16.0.128 255.255.255.128 10.10.0.2 -> ip route to remote location 1
ip route 172.16.201.0 255.255.255.128 10.10.1.214 -> ip route to remote location 250
line 0/322 0/357
no flush-at-activation
login local
modem InOut
modem autoconfigure discovery
transport input all
transport output all
autoselect during-login
autoselect ppp
This is my configuration for dialin and DDR dialout but it doesn't work. My idea was to make two dialer pool-member on interface Serial 1/0:15 where dialer pool-member 1 is for incoming connections (dialin) and where dialer pool-member 2 is for outgoing connections (DDR dialout) with reserved 2 B channels.
interface Loopback1
ip address 10.10.0.1 255.255.255.255
interface Loopback250
ip address 10.10.1.213 255.255.255.255
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool-member 2 min-link 1 max-link 2
no fair-queue
no cdp enable
interface Dialer1
ip unnumbered Loopback1
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 2
dialer idle-timeout 300
dialer string XXXXX
dialer-group 1
peer default ip address 10.10.0.2
no fair-queue
no cdp enable
ppp pap sent-username USERNAME password 0 cisco
ppp ipcp address accept -> makes remote location to accept IP address
interface Dialer250
ip unnumbered Loopback250
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 2
dialer string XXXXX
dialer-group 1
peer default ip address 10.10.1.214
no fair-queue
no cdp enable
ip route 172.16.0.128 255.255.255.128 10.10.0.2 -> route for remote location 1 when remote location dials in
ip route 172.16.0.128 255.255.255.128 Dialer1 -> route for same remote location 1 when Cisco makes DDR dial out
ip route 172.16.201.0 255.255.255.128 Dialer250
dialer-list 1 protocol ip permit
I would be very thankfull for any suggestion!
alanssie Tue, 09/21/2010 - 15:42
No very sure I understand your point here, you said that the remote dial via analog, but you want to make dialout
via the digital  ?
With the current configuration you will use a B-channel, but as no modem trigger the call so you will never do analog
in the B-channel
If you want to dialout using the anallog the group-async is the interface to point as pool-member
and you will need  a chat-script to provide the at command to the internal modem
Alain
Related Content
