Allow Offnet to Offnet transfer
Sep 8th, 2010
Hi! We have a customer who wants to allow Offnet to Offnet transfer (they realise the Toll Frad ri
sk, but insist for various reasons). A part from setting "Block Offnet to Offnet transfer" to False in the Service Parameters.
Do I need to change the RP and GWs from currently Offnet to Onnet or can I leave them as they are?
Annika
Jaime Valencia Wed, 09/08/2010 - 07:12
  • Cisco Employee,
  • Hall of Fame,
    2011
That's really all you need. If your configuration already allows a user to dial to the PSTN that's all they need to do the transfer.
GWs should be tagged appropriately as on-net or off-net so I don't recommend to change those.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
