Hi could you please solve this issue
Sep 8th, 2010
Hi i have a cisco 2511 router its having 8 mb flash. i am tring to load ios on rommon mode but its showing error. i.e. F3: 3641976+85568+217784 at 0x3000060
This error getting when i am trying to use this comman >L c2500-i-l.113-11a.bin 192.168.1.1.
I was also tried to >b c2500-i-l.113-11a.bin 192.168.1.1 at that time it will show like bellow
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3000 Software (IGS-IN-L), Version 11.0(4), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1995 by cisco Systems, Inc.
Compiled Mon 18-Dec-95 17:54 by alanyu
Image text-base: 0x0301F780, data-base: 0x00001000
cisco 2511 (68030) processor (revision L) with 2044K/2048K bytes of memory.
Processor board ID 02824467, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
16 terminal lines.
32K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash partition 1 (Read ONLY)
4096K bytes of processor board System flash partition 2 (Read/Write)
%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
%LINK-3-UPDOWN: Interface Ethernet0, changed state to up
%LINK-3-UPDOWN: Interface Serial0, changed state to down
%LINK-3-UPDOWN: Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async1, changed state to up
%LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
%SYS-5-CONFIG_I: Configured from m
%SYS-5-RESTART: System restarted --
%LINK-3-UPDOWN: Interface Async1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
2500 processor with 2048 Kbytes of main memory
Abort at 0x10EA82E (PC)
$            Toggle cache state
B [filename] [TFTP Server IP address | TFTP Server Name]
             Load and execute system image from ROM or from TFTP server
C [address]  Continue execution [optional address]
D /S M L V   Deposit value V of size S into location L with modifier M
E /S M L     Examine location L with size S with modifier M
G [address]  Begin execution
H            Help for commands
I            Initialize
K            Stack trace
L [filename] [TFTP Server IP address
             Load system image from ROM or from TFTP server, but do not
             begin execution
O            Show configuration register option settings
P            Set the break point
S            Single step next instruction
T function   Test device (? for help)
Deposit and Examine sizes may be B (byte), L (long) or S (short).
Modifiers may be R (register) or S (byte swap).
Register names are: D0-D7, A0-A6, SS, US, SR, and PC
>C 192.168.1.2
Exception: Line 1111 Emulator at 0x1D6 (PC)
           cisco Systems, Inc.
Abort at 0x30F74C4 (PC)
           cisco Systems, Inc.
Bridging software.
16 terminal lines.
%SYS-5-CONFIG_I: Configured from memory by console
Then it will hanged. after this step it will process untill unless restart
what is the problem could you please help me
Advancely thanks and regards
Lakshminarayana
Reza Sharifi Wed, 09/08/2010 - 09:35
  • Cisco Designated VIP,
    2017 LAN
That looks like memory issue.  I see, you only have 4mb memory.  The max on 2500 is 16mb flash and 16mb memory.  So upgrade to 16mb memory and try again.
Reza
Lakshminarayana... Wed, 09/08/2010 - 12:26
Thanks for your replay Reza
but i did not have that much of memory  so could you pelase update me to compatable to that memory
memory details are 4 mb ram and 8mb flash. let me know first is there any ios to compatable for this memory modules. if have could you please update with the link.
