Using ASDM on 5520 how do you allow only a range of ports 8900-9100
Answered Question
Sep 8th, 2010
Am a very novice.Have set up the security rules and can pass and block devices by IP
address but want to further limit to only a range of ports to go through and can't seem to find any
where in documents that talks about how to do this.
Correct Answer by sachinga.hcl about 6 years 5 months ago
HI Lee,
Kindly go through the following while configuring the ACL through ASDM:
Service—Choose this option to specify a port number, a range of ports, or a well-known service name or group from a list of services.
...—Lets you select, add, edit, delete, or find an existing service from a preconfigured list.
Protocol and Service—Specifies the protocol and service to which this ACE filter applies. Service groups let you identify multiple non-contiguous port numbers that you want the ACL to match. For example, if you want to filter HTTP, FTP, and port numbers 5, 8, and 9, define a service group that includes all these ports. Without service groups, you would have to create a separate rule for each port.
You can create service groups for TCP, UDP, TCP-UDP, ICMP, and other protocols. A service group with the TCP-UDP protocol contains services, ports, and ranges that might use either the TCP or UDP protocol.
–Protocol—Selects the protocol to which this rule applies. Possible values are ip, tcp, udp, icmp, and other. The remaining available fields in the Protocol and Service area depend upon the protocol you select. The next few bullets describe the consequences of each of these selections:
–Protocol: TCP and UDP—Selects the TCP/UDP protocol for the rule. The Source Port and Destination Port areas allow you to specify the ports that the ACL uses to match packets.
Source Port/Destination Port—(Available only for TCP and UDP protocols) Specifies an operator and a port number, a range of ports, or a well-known service name from a list of services, such as HTTP or FTP. The operator list specifies how the ACL matches the port. Choose one of the following operators: = (equals the port number), not = (does not equal the port number), > (greater than the port number), < (less than the port number), range (equal to one of the port numbers in the range).
–Group—(Available only for TCP and UDP protocols) Selects a source port service group. The Browse (...) button opens the Browse Source Port or Browse Destination Port dialog box.
–Protocol: ICMP—Lets you choose an ICMP type or ICMP group from a preconfigured list or browse (...) for an ICMP group. The Browse button opens the Browse ICMP dialog box.
–Protocol: IP—Specifies the IP protocol for the rule in the IP protocol box. No other fields are available when you make this selection.
–Protocol: Other—Lets you choose a protocol from a drop-down list, choose a protocol group from a drop-down list, or browse for a protocol group. The Browse (...) button opens the Browse Other dialog box.
For details in this regard go through the following link and then search range of ports.
https://www.cisco.com/en/US/docs/security/asdm/6_1/user/guide/svcrules.html
Sachin Garg
Correct Answer by Panos Kampanakis about 6 years 5 months ago
On ASDM when you add an ACL line, in the protocol field you can put tcp/80-85, if for example you want to allow port range 80 to 85 for tcp.
I hope it helps.
PK
Overall Rating: 5 (2 ratings)
Correct Answer
Panos Kampanakis Wed, 09/08/2010 - 08:44
I hope it helps.
PK
Correct Answer
sachinga.hcl Wed, 09/08/2010 - 09:38
HI Lee,
Sachin Garg
