I have already setup the wds function for WRVS4400n so that its signal can be repeated. Then i also configured 2 WAP200 as repeaters.
WAP200 A has the IP of 192.168.1.3 and WAP200 B has the IP of 192.168.1.4.
The 3 APs has the WEP security setting on and all of the 3 has the same SSID. After firing them up, i tried to access the WAP200 A and B using the IP when i am on the wired connect with the WRVS4400n. Only I can access B.
Is there anything wrong with my configuration?
